| | | Forums66 Topics128,057 Posts1,055,808 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I bought headliner for this truck Installed the front and back headliner. My question is how does the center get put together blind clips or what?
Bennie | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | You should have a center rib support that the center retainer mounts to. The headliner slides in at the center and is retained front and rear with trim strips. I have mine at the chrome shop now but have seen some stainless. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I thought that is how the center is put together but I don't have the center strip. I have looked in all of the parts places and have not found one. Do you know where I could get one?
Bennie | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | You might have to check e-bay, I'll check my stuff and see if I have a spare out there. | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks let me know if you have one and I will check on e-bay | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I have half of what you need. I have the base bow but not the trim piece that screws to the base bow. the base bow attaches with two screws above each door opening. | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I really don't understand the terms let me understand what I need comes in 3 pieces? You have the bow that goes across the top of the cab? I will still need the pieces that attaches the bow to the top of the doors?
Bennie | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | There is just two pieces, There's the piece that mounts closest to the roof and the other piece mounts to it. The piece I have mounts closest to the roof it requires two mounting screws for each side. The piece I do not have mounts to the piece I have I think with about 6 screws which divides the headliner. If you look midways between the upper door sill you should see two screw holes on each side. I guess I could take a picture of the piece I have. Hope this helps. G | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | There are 1 piece either ABS or Fiberglass available from Chevs of the 40's, the Filling Station or Jim carters. I have seen the pieces on ebay for the two piece. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Does anybody put (or have recommendations) for insulation between the headliner and metal roof?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | oldbluetruck, I have insulated the roof of my 46. I first put a layer of peel-n-seal on the metal roof to cut down on the noise, then I got a water heater blanket, you know the ones that are foil on one side and ground up carpet on the other. I used 3m spray adhesive to glue it up to the roof. Shinney side towards the interior of the cab. It's been that way for about 8 years now and works fine. George | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks George. I didn't think of the water heater blanket. Nice idea.
Unfortuneately, I looked up the peel-n-seal and it was not available in any Lowes near me. I wonder why?
