8 members (mason86, klhansen, tclederman, Ponchogl, dt235sd, Phak1, Hanks custodian, Otto Skorzeny),
70
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,672 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I am redoing my brakes, and I have the shoes and wheel cylinders. But I was hoping to find the rest of the hardware kit, i.e. springs, hold down pins, etc. Anyone know where I can get a full kit? I'd hate to track down all the bits individually.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Are you referring to the brake shoe anchor pin and locks? I think they are sold individually. Jim Carter has most of it, but there descriptions are vague on models. Obsolete Chevy has a rear brake lock pin, part # 477448, listed for $20 a pop. Good luck! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What size and year truck? 1951 1/2 ton or 1 ton?
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I have a 1951 1 Ton. I am doing the rear brakes.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Kanter Auto may have your kit also. They're knowledgeable and easy to work with. Have fun and good luck Dan | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Thanks. The trouble I run into is that the only full kits or pieces available are for 1/2 or 3/4 ton trucks.
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I bought my small parts kit at my local parts store.
Bruce | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | So I opened my box with the remanufactured brakes. They are for a newer style truck. Grrrr! I am just going to have to reline them I guess.
Even more surprising is... Why is the wheel cylinder larger on my truck than the 1 ton rear wheel cylinders I ordered from JCarter's? Anybody got any ideas? I suspect that parts may have been swapped, since the existing brake shoes are bonded and not the factory riveted shoes.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Dave - the 1 ton brake shoes are supposed to be bonded.
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | hmmm???
So I'm wondering if the wheel cylinders are just a Heavy Duty version or something? I have a leaky cylinder that needs replacing.
I posted this question as a new topic.
