| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 39 | I need help in finding the following part. It is the guide that holds the door window channel on the back of the door. Please see picture. I think I've seen them on a vendors site but can find now. One was broken when removed. Thank you for your help, Scott http://i740.photobucket.com/albums/xx49/49chevyia/IMG_1458.jpg | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | These channel guides are for 51-54 but you may find them here for your 49. I think the earlier models had window guidies that are wider. http://www.classicparts.com/Door-Rubber/products/4/also try JimCarter or American Classic | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Nice truck. What side are you looking for?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 39 | I'm not completely sure. I think it is the driver's side. I'll have to look closer when I get back in town.
Thx for the kind words. It's almost done except for the interior overhead and the door windows. I quess it's time I put something in the gallery.
| | | | | Joined: Jul 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 39 | looks like drivers side.
THX for everyone's help. Achipmunk - have a great weekend! | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I could only find these guides used. Jim Carter said they were working on reproducing them but don't have them yet. The front rails are the opposite sides rear. Hence, the front driver side is the passenger sides rear. And vice versa.
They seem to rust out just above the block that is spot welded to the front of the door. And the drivers side seems to be the worst of the two to do this.
I hope this helps
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | I know I would rather have a good used US made one then an asian made part, kinda goes for almost all parts. | | |
