9 members (Cosmo, Samantha, Otto Skorzeny, Brian Moore, Jims46, Ponchogl, moparguy, KEVINSKI, 55shaker), 83 guests, and 2 robots.
Topics128,030
Posts1,055,424
Members48,422
#754128 06/13/2011 1:54 AM
I've been wondering lately if the front leaf springs on my '53 3600 are worn out. The truck rides rough, and feels like theres no give in the front suspension at all. I know its not going to be smooth, but it just seems like there not doing anything. I was under the truck yesterday and noticed the leafs seem like their drooping down. If I put a straight edge between the ubolt and the front shackle it shows that it droops down. Is there supposed to be a noticeable arch?
Leaf picture:
http://i54.tinypic.com/2aihbsy.jpg
I won't address the ride but your springs should have some arch to them while at rest. I would guess that the shackle should be vertical. My springs look like yours but I don't have a problem with the ride.
1951 1 Ton Completed
The springs do look a little tired also looks like you the oils leaking out of your right front shock.
ttodd #757661 06/26/2011 2:18 PM
Make sure all six pins are free to move. I found one frozen up on my truck.
#757691 06/26/2011 4:19 PM
I,ll be darned if that fluid does,nt look like green anti freeze to me.
regards,
steve sr.
Mine were worn bad enough they wouldn't bounce even on the roughest roads. Look at the bottom sides and see if the lower springs have worn into the ones above them. Mine had steps at the meeting point so they had no where to slide. I ground the steps smooth and cut a radius on the lower spring edge so there was room to move. I also added teflon strips between each leaf for more give. It rides really good now for a old truck!
Joe
Joe H #758836 06/30/2011 10:14 PM
You were right Joe, the springs are very worn into each other. That would explain the rough ride, ha. It turns out the 3/4 and 1/2 tons use the same leaf springs in 1953, so I can probably get new springs reasonably cheap, thank God, 3/4 ton price markup was starting to kill me! Anyone have any recommendations on where I should get new springs?
S Online: Content
St. Louis Spring is good, as is Eaton Detroit Spring. Both supply springs to original specs, or to customer specs. I bought rear springs from Eaton Detroit, and am getting front springs from St. Louis Spring (my parents are near there, so I can save on shipping).
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Samantha #758867 07/01/2011 12:50 AM
Check local, it will save shipping.
Joe
I do believe that your front springs should look like this Fern. The ride is still going to be quite stiff.
Keep in mind that these trucks were made for hauling not a joy ride in the country.
http://www.pbase.com/dennygraham/image/136038177/large
http://www.pbase.com/dennygraham/image/136038185/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
