3 members (Otto Skorzeny, dwreills, Peggy M), 56 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#757762 06/26/2011 9:01 PM
Getting ready to clean up and upgrade some the wiring [such as a larger positive cable per prior post] and I was wondering what to do with the ignition switch if anything. My truck has a 350 SBC that the previous owner appears to have installed a push switch on the dash to engage the starter. Didn't the trucks originally have a floor start switch? [at least that is what the assembly manual seems to indicate]
What should I be looking at with this push switch to assure I am not loosing any power and that it does not create any other electrical concerns?
Thanks.
Six cylinder trucks had the button on the floor, V8s had a key switch.
Your solenoid doesn't care if your switch is a push button or integral to the ignition switch. All a switch does is make a connection. No reason to replace the button unless you just want to.
Thanks for that, yeah the truck was previously a six cylinder and the ignition key and pass door are the same so it is obviously original. Not looking to change anything I dont need to, plus it is a stainless steel button and looks pretty good on the dash as it is!
