0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I have just completed putting new brake lines,wheel cylinders,brake pads,springs etc. All new except Master cylinder ( Looks very new )Still fluid in Master. I replaced all my front bearings and races and grease cups. Put hub back on.. and the front wheels spins freely. I got new rear drums and put them on and I have a slight rub. I have the star adjuster all the way in. I just read the Manual and it says to disconnect the parking brake. I'm on duty so I can't do that today...Can that be the problem with the rear drums Dragging slightly? So, my main question is how should I go about filling my dry lines? I have a small hand vaccum pump for brakes...I was going to make sure the resevoir was full and create a vaccum with the pump and then start with the left front and work my way back.per pump manual...Since I've never done a complete dry system before..does this sound reasonable? or do you have any other ways...Also I'm confused about after the brakes are bleed you turn the star wheel back 7 notches..? What happens if you don't have the seven notches on the wheel?
Just trying to do this right the first time. Any help would be great. Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Brakes need to be fully adjusted per the manual before you bleed the brakes.
Use your brake vac to get all the old fluid out of the mc reservoir and start with new fluid.
Then use the vac tool to bleed as you described. Refill the reservoir after each wheel. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | So, Cletis...I'm going to adjust the star wheel to create a slight drag on the wheels...( thru the slot in the back of the backing plate). For both front and rear . Once they are adjusted to a slight drag...turn the adjuster star backwards 7 clicks. then Bleed brakes....Correct ? Again If I don't have 7 clicks is that ok? Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't see why you wouldn't have 7 clicks. That is less than one revolution. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Cletis, my only concern is that my back brakes are already dragging ( slightly ) even before bleeding. I don't know if the parking brake still being attached is causing it or not. Will bleeding the brakes cause them to constrict and cause this to go away...then I can adjust and turn it the 7 notches? Thanks Again | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Dont worry about slight drags. New shoes & new drums havnt been seated yet. They will have some drag untill they are broke in. Adjust the starwheel up till you get a heavy drag. Then back it off about 5 notches. Unless you know the master cyl has been replaced or rebuilt recently I would put a kit in it. When you start moveing the parts to a different possition they can fail soon after the job is done. A good master cyl. helps with the bleeding also. When you get through the pedal should barely go down. You just apply pressure to it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If I remember correctly we were always told to crank up the brake until you felt a slight drag. So much of what we knew was stuff old mechanics told us.
~Jim
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I am about the charge a new brake system. I am following the thread so far. Can someone refresh me on bleeding the master cylinder. I think I understood to bleed the master first. To bleed the master connect a scrap break line and route line back into the reservoir and then generally depress pedal until all air is expelled? Then connect brake line from master to first junction? Can someone confirm? I presume if I keep fluid in both (brake and clutch) chambers I can do them one at a time? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You have the procedure down. Yes, do the brake and clutch one at a time. | | |
