3 members (Paul Mullen, delwrench, Jims46), 63 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
I'm working on a 1952 GMC on a S10 frame with a sbc. I'm having trouble deciding what 12v battery to use and where to mount it? The original floor hole is blocked by the frame. The firewall area has air and heat lines there. If I put it in the truck bed it just kind of sets there in the open. I've read about the dry cell type batteries that could set under the front seat. HELP!!!!!!!!!!!!!!!!! Thanks
The " Optima " line of batteries can be mounted in just about any orientation you need.
1940 Chevy KC 1/2-Ton
Several rod companies offer really slick battery boxes that drop down for access here is and example of one.
http://www.speedwaymotors.com/Drop-out-Battery-Box,5047.html
They also carry other styles and have great customer service.
I bought mine at CPP Classic Performance Products CPP for $109.00 This looks to be the same product that speedway is offering. Mine is stainless (you can get black) group 24. The Group 26 is a bit larger and a bit more $.
MY BOX
~Jim
