5 members (baldeagle, Wayne67vert, klhansen, Joe H, Gray_Ghost), 92 guests, and 9 robots.
Topics128,019
Posts1,055,343
Members48,419
#7565 03/22/2004 3:56 PM
Pal
Offline
Have any of you used a 4 bbl intake mainfold on these stovebolts? I see that they are available from Whitneys. Personally, I'm leaning toward Langdons progressive 2bbl set up, but I do like to check out all options. smile
So, 4 bbl conversion on a 250, Good or Bad?
Dave
35 + years of rollin' steel!
#7566 03/22/2004 7:10 PM
I'm happy with my Edelbrock 500 on a water heated Offy (on a 250). 14,500 miles since 12/03 and no trouble. Easy to tune, runs great.
#7567 03/22/2004 7:37 PM
Chuck,
You are really putting miles on that baby! Whew, 14500 in < 4 months? How far is your daily commute?
Professional Novice
#7568 03/22/2004 11:19 PM
Pal,
If your 250 will remain stock other than the carburetor then I don't recommend a 4 barrel. The Holley-Weber progressive 2 barrel will work MUCH better with the stock engine. Chuck's engine is a little hotter than stock so the Edelbrock works with his. A stock 250 (or 292) would be overcarbed with a 500 cfm 4 barrel.
I have the same carb (500 cfm Edelbrock) and intake (Offenhauser 4 barrel) as chuckthetruck on a .060 overbored 292 that has headers and a mild cam. Worked good right out of the box. Still needs tuning for optimum performance. If I were buying again I'd probably go for the progressive 2 bbl for my engine. I've NEVER gone into the secondaries on the 4 barrel and don't think the engine could handle the extra fuel/air anyways.
-ftyler
#7569 03/23/2004 11:59 AM
12/02 sorry. It's so much fun it seems like only yesterday.
FT floor that puppy! Wind it up - you'll be into the secondaries. It'll handle it just fine.
#7570 03/23/2004 1:45 PM
Pal
Offline
Currently my 250 is stock (.30 over) and electronic ignition from a 75-76. I'm adding headers, maybe a newer intake manifold (gonna try planing mine 1st). I think I'll go the 2 BBL route (read: cheapskate), and save my money for an overdrive unit and paint job.
#7571 03/23/2004 7:42 PM
There's a guy at inliners who has a 250 with dual holley quads in a Nova. cool But his 250 is far from stock.
Fred
52 3600
69 C-10
#7572 03/23/2004 9:31 PM
Fred if you're talking about Larry, yes his Nova is far from stock. Let's just say there's a really good reason he has a F@RD 9 inch rear end under that Nova. eek
-ftyler
