| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Have any of you used a 4 bbl intake mainfold on these stovebolts? I see that they are available from Whitneys. Personally, I'm leaning toward Langdons progressive 2bbl set up, but I do like to check out all options. So, 4 bbl conversion on a 250, Good or Bad? Dave
35 + years of rollin' steel!
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I'm happy with my Edelbrock 500 on a water heated Offy (on a 250). 14,500 miles since 12/03 and no trouble. Easy to tune, runs great. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Chuck, You are really putting miles on that baby! Whew, 14500 in < 4 months? How far is your daily commute?
Professional Novice
#7568 03/22/2004 11:19 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Pal,
If your 250 will remain stock other than the carburetor then I don't recommend a 4 barrel. The Holley-Weber progressive 2 barrel will work MUCH better with the stock engine. Chuck's engine is a little hotter than stock so the Edelbrock works with his. A stock 250 (or 292) would be overcarbed with a 500 cfm 4 barrel.
I have the same carb (500 cfm Edelbrock) and intake (Offenhauser 4 barrel) as chuckthetruck on a .060 overbored 292 that has headers and a mild cam. Worked good right out of the box. Still needs tuning for optimum performance. If I were buying again I'd probably go for the progressive 2 bbl for my engine. I've NEVER gone into the secondaries on the 4 barrel and don't think the engine could handle the extra fuel/air anyways.
-ftyler | | |
#7569 03/23/2004 11:59 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | 12/02 sorry. It's so much fun it seems like only yesterday. FT floor that puppy! Wind it up - you'll be into the secondaries. It'll handle it just fine. | | | | | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Currently my 250 is stock (.30 over) and electronic ignition from a 75-76. I'm adding headers, maybe a newer intake manifold (gonna try planing mine 1st). I think I'll go the 2 BBL route (read: cheapskate), and save my money for an overdrive unit and paint job.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There's a guy at inliners who has a 250 with dual holley quads in a Nova.  But his 250 is far from stock.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Fred if you're talking about Larry, yes his Nova is far from stock. Let's just say there's a really good reason he has a F@RD 9 inch rear end under that Nova. -ftyler | | |
