| | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | I started the modification of the 216 side cover for the 235 I have in my 37,I will put it over the existing 235 cover and cut out around the plugs and had to cut out more around the distributor and road draft tube. Since there is a outward dimple on the 235 cover I heated the 216 cover up and made one on the 216 cover so it would fit better,tomorrow I will weld some nuts on the back of the 216 cover so I can bolt the coil bracket to it. I have taken pics so when done I will post them. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It will be interesting to see it when you are done. It sounds like quiet the disguise! | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | It will be noticeable to anyone who really knows the motors but I hope it will fool a few of the so called experts that lurk at the shows and cruise ins. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | The cover is done and on the motor but dont know how to post pics on here. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Jeff, The "Pictures" section in the "Stovebolt Owner's Manual" contains the "official" instructions for posting images. You could also add a link to the images in your Stovebolt-signature webpage, along with that great-looking '37. Hoyt
Last edited by hoyt; 06/19/2011 3:41 AM. Reason: I couldn't even spell my own name correctly!
| | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | In the intro pic that looks amazingly good on your 235. If you have any other pics on Snapfish, remember, users have to sign up to log in and view the rest.
Drew
| | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Very nice work and very clever.
Drew
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | It turned out better then I thought it would,I thought I was done but forgot I have a alternator on the other side of the motor that needs to go and a generator put back on. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | If I ever go back with the aluminum valve cover I would love to have one of those aluminum side cover since the aluminum valve cover I have is for a 216 and could continue to make it look like a 216. | | |
