| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 5 New Guy | | New Guy Joined: Aug 2010 Posts: 5 | What needs to be know and done to make this work? Found one asking 150.00 for whole front clip. Its got disc brakes and 5 lug. Thanks in advance for info.
Drive it like you stole it!......If its to loud your to old!....The best time to buy a new project is when you see it!..................
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | whole clip will bolt right in, or you can use the a-arms & spindles only. Use 71-2 master cyl & prop valve, run new lines as needed. | | |
