2 members (Peggy M, Gdads51), 106 guests, and 3 robots.
Topics128,169
Posts1,057,043
Members48,458
What needs to be know and done to make this work? Found one asking 150.00 for whole front clip. Its got disc brakes and 5 lug. Thanks in advance for info.
Drive it like you stole it!......If its to loud your to old!....The best time to buy a new project is when you see it!..................
whole clip will bolt right in, or you can use the a-arms & spindles only. Use 71-2 master cyl & prop valve, run new lines as needed.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
This is the most comprehensive thread I am aware of regarding front suspension/brake swaps:
http://67-72chevytrucks.com/vboard/showthread.php?t=367260
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
