| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 14 New Guy | | New Guy Joined: Jun 2011 Posts: 14 | Any body know where I can get some? It's a 366. TIA
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Any exhaust shop can build what you need | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | They didn't use exhaust pipes, only turndowns on the mufflers. | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | chrome stacks sound good, but turn downs under the bed before the rear axle is the standard on a dump truck.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Chris_CoZi, welcome, there is not a lot to a truck exhaust system, but here goes, all part numbers are Walker, and prices are from Rock Auto exhaust pipe p/n 45532 $52.79 exhaust pipe p/n 44511 $44.88 turn down p/n 41062 $10.10, two required mufflers p/n 21259 $64.79 two required I hope that helps.
| | | | | Joined: Jun 2011 Posts: 14 New Guy | | New Guy Joined: Jun 2011 Posts: 14 | Thanks all. Local shop made the pipes. Will keep the part numbers handy. :-) | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Use Glass Packs or Turbo's for Mufflers.
Not only a lot cheaper, but it will run better and sound better too.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
