3 members (Gdads51, 2 invisible), 60 guests, and 1 robot.
Topics128,115
Posts1,056,636
Members48,450
Could someone help identify a flywheel and pressure plate. I forget where I got these but it's a matching set with the the numbers GM4 3973456N on the back of the flywheel. The clutch disc and pressure plate are 12" diameter. The pressure plate bolts to the flywheel with 6 bolts. The flywheel to crankshaft bolt pattern seems to be larger in diameter than a 235/261 crank and does not have the three locating pins. I'm thinking it could be a 302 GMC but the crankshaft bolt hole diameter (7/16) and bolt pattern diameter is smaller than the other GMC 302 flywheels I have. Maybe and early GMC flywheel? Any help would be appreciated, thanks!
Paul.
1948 Chevy 6400
1964 Chevy 1/2 Ton
That number isn't familliar to me. Does the flywheel have timing marks on it like a gmc 270 or 302? Could it be a chevy v8 flywheel?
thats a late 60s, early 70s chevy v8 flywheel
50 chevy 3100
Okay thank you for the replies guys! Makes me wonder where in the heck I got it from.
Maybe I'll put it in the parts for sale classified, it'll do someone some good...
Thanks again, Paul.
1948 Chevy 6400
1964 Chevy 1/2 Ton
