7 members (LAJones48, Barry Martak, Otto Skorzeny, Waveski, Shaffer's1950, Rusty Heaps, 1 invisible), 110 guests, and 2 robots.
Topics128,094
Posts1,056,465
Members48,443
#754389 06/14/2011 1:37 AM
Do all 261 blocks use the "rope" seal on rear main? If not - what years used modern type seal?
This question about the rear main seals has come before. The answer is not totally clear, at least to me. A rplacement 261 short block for a 1954 that I bought in 1958 came with a rope seal (that really leaked.) Another 1954 261 short block that was purchased in the early seventies came with an orange elastomeric seal.
Hoyt
I can not clear up when Chev changed to a elastomeric seal but I know they did. I have a NOS GM elastomeric seal .
My Blog
I believe ALL 216-235-261 engines came with rope seals.
My 59 261 has the modern rubber seal.
Tommy
59 apache 1/2t
261 short stepside
Here are some other references for further information and confusion:
Ecklers, 1949-54
Ecklers, 1955-62
Chevs of the 40s, rope and rubber
Bob Adler
Best Gasket, Rope and Rubber
I have some 261s that I will be rebuilding over the next few years. I'm not sure what I will do. I might try the conversion to the one-piece seal that was discussed a few months ago. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=687066#Post687066
Hoyt
I believe any 216-235-261 that has a "rubber" seal, the seal has been changed. When I built my engine in 1990, I was told rubber would not work in a 261, but the builder put rubber in without telling me. The first thing after I got the engine in the truck, the seal started leaking. I replaced it with a rope seal and haven't had a problem since. That's not to say a "rubber" seal wouldn't work, but a rope seal, properly installed and in my opinion, works best.
I have had very good luck with the rubber/elastomeric seal.
There are two things you need to watch out for when using one.
First, if the seal surface of the crank has been turned down they will not work, use a rope.
Second, I have seen a number of blocks where the seal groove is not concentric with the bearing bore. In this case a rope seal is the only way.
My Blog
I had my 216 machined for a full circle seal. It just seems like the right thing to do
When I rebuilt my 1960 261 in 1972, the gasket kit from NAPA (Fel-Pro?) came with a rope seal and a rubber seal. I used the rubber seal. However, the 1960 Chevrolet Truck Shop Manual describes (with illustration/picture) the braided rope-style rear main bearing oil seal.
