Do you have the " wishbone" looking support hooked up? It goes from cab to top of radiator support. You adjust the nose position using this, it just might let you pull it back far enough to line up. If the engine is mounted, you could double check the location of the radiator. When correct, the fan will be very close to the core.
Joe
