1 members (Gdads51),
124
Mod | | | Forums66 Topics128,204 Posts1,057,312 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Would a 37 1/2 ton pickup have had weather stripping around the doors?
If so, where?
Any recommendations on a supplier?
Thanks. | | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | Mine did not come with any. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | 1937 Chev trucks had no rubber weather strip. Inside the truck doors was windlace which was made to act as a weather strip of sorts. It was held in place by the narrow trim pieces around the door opening from the bottom of the latch side, up the side to the top and across the top where the trim piece stops. At that point the windlace moves to the door itself down the hinge side to the bottom. There was a piece of rubber that went across the bottom of the door sill that had some sealing ability. That was it!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks to all for the replies, and thanks to Alvin for the pics.
Last question, Jim Carter's offers the windlace in both black and brown; which is closest to the original?
Thanks, Mike | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i got the black for my 40 but didnt install it yet even though i was sent some reference pics. i would like to a complete installation before i proceed. | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Hello ArmyMike, We had a little chat about this a few months back. I also have a 37. Achipmonk posted some excellant pix with the windlace on the door. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The factory stock color for the interior was brown, no matter what color the outside was. Even the blue and the black truck had brown interiors, not just the seats , but the whole interior. The dash and the door panels along with the the top back of the cab and the metal trim pieces were painted in a wrinkle brown
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | My '37 has a trim piece above the door, but it does not continue down the latch side of the door opening. Am I missing a piece of trim, or should I insert the windlace between the door frame and the sheet metal of the cab interior?
BTW, Fillingstation.com has a Cab Windlace Vertical Retainer (http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z5AAEOQ~P25.00~~~~S3970NIANH24153214050G~Z5Z5Z5~Z5Z5Z50000014x#) that they say fits vertically between the dash and the floor. What would be the purpose of this? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | There is an actual metal strip that goes over the sheet metal of the interior that holds the weather strip on around the door. The part I'm talking about is about 35" long. Below it, the stripping fits behind the cab re-enforcement piece to the bottom of the door. The strip above the door finishes out the cab part of the windlace. At the top of the door where it hits the front piler, the strip starts on the door itself to the bottom of the door. The part The Filling Station has sounds like it fits the edge of the kick panel below the dash.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks Joe. Between your description, Alvin's pics and some others I've found on the web I think I understand. Looks like I'm missing that 35" metal strip you mention that would hold the windlace to the latch side of the door opening. | | |
