3 members (TUTS 59, Maybellene, baldeagle), 61 guests, and 2 robots.
Topics128,060
Posts1,055,835
#753726 06/11/2011 4:19 AM
Trying to find a wiring diagram for a 3 tab 12 volt regulator. I'm not sure that the voltage regulator is an original style. The truck has a alternator that charges when the field is jumped from the battery.
Any help with this would be greatly appreciated. I really don't want to start fabricating brackets for a 1 wire alternator.
Rick
62 C-60/Towers Fire Apparatus Fire Engine
Cletis #753790 06/11/2011 1:53 PM
Thanks for the drawing. I found this earlier, but it shows a 4 wire system. I have a 3 wire system.
Rick
Ex Hall Monitor
Ex Hall Monitor
What year truck are we working with, and is the electric system original? The only system I'm aware of other than the internal-regulated 10SI alternator is the 4-wire system shown in the diagram. The 3-wire regulator in the illustration is for a generator, not an alternator.
It is a 1962 C60 with a 327. It appears to have the original screw down terminal connections, but the VR looks awfully new. I am still tracing down wires to see if it is 4 wire system that has been hosed up.
Rick
OK, one more time- - - - -does it have a generator (1 foot long, skinny, with a stepped-down back end and about 4" in diameter), or an alternator (about 7" in diameter and 5" from front to back)? It makes a huge difference in the wiing and the voltage regulation process!
1962/63 was about the time General Motors switched from generators to alternators.
Found a 4th tab, it is the ign sw and only has power in the run position. I with it was laid out the same as a standard GM regulator. Still chasing wires
Rick
It is an alternator. Delco Remy Mod # 1117765.
http://www.flickr.com/photos/rlsidebottom/5823300256/in/photostream/lightbox/
Here is the layout of the current VR
http://www.flickr.com/photos/rlsidebottom/5822802889/
Rick
3B Offline
Hy 62ChevC60, I believe your alternator is a 6.2 perforated stator delcotron. There were numerous regulators made for these, both transistorized and mechanical. Could you post a picture of your regulator? There is a spade terminal regulator from the mid to late 60s that could be used to regulate this alternator, using this regulator only requires two connections, one from the ignition switch to the number three terminal, and one from the "F" terminal to the field connection at the alternator, hope that helps.
3B #754054 06/12/2011 9:52 PM
Here is a pic of the regulator as wired when I bought it.
http://www.flickr.com/photos/rlsidebottom/5826019744/in/photostream
A new issue cropped up after tracing some wires down. THe engine will continue running after the key switch is turned off. You have to kill it with the master battery switch that was installed at the Fire body manufacture.
Rick
3B Offline
Hy 62ChevC60, thanks for the picture, it sounds like they are using an ignition feed to activate the alternator which is back feeding the igniton circuit when you turn off the key, you could put a diode in that feed or switch the alternator feed to the accessory side of the ignition switch.
I have a Motor's heavy truck manual with a little information about that alternator, but no clear schematics showing how it's wired with a mechanical regulator. It does mention that there's a relay used to energize the alternator on startup. If the relay has been eliminated, it's possible there's a back-feed to the ignition circuit that would keep it running on shutdown. The regulator you picture does not look like an original-equipment Delco item, and it might be wired somewhat differently internally. The transistorized regulator used with that alternator was much more common, and it only had a 3-wire connector, with the regulator base grounded to the body metal. I ran one on a 64 White Freightliner, set up for positive ground.
Hotrod, i have not seen anything on a transistorized VR.
3B and Hotrod, The issue with it running after the key is turned off just started. There is a master battery switch that I can use to shut it down.
Thanks for all the help, when I get smart, I'll try and return the favor.
Rick
