1 members (Bill Hanlon),
137
9
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Its finally time to fix or replace the original radiator in my 41. Has anybody swapped in one of these new aluminum radiators from superior or AFCO? Or should I just go for recoring mine, I'd rather just deal with the problem instead of pouring in bars leak or some other thing. | | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | i wish i could help you, but, i'm in the same position myself. new radiators cost between $350 and $900. i am gonna watch this post carefully. i'm at the start of a partial restoration of a 41 1.5 ton. the radiator is one of the big ticket items i will be needing. after sitting 50 years, the original was toast. good luck.
~marc | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i got all of mine recored. priced ranged anywhere from $350-$400. | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Well, I bit the bullet on Friday and ordered a new radiator from cool craft. It isn't cheap but they do have a warranty, and it is made here in the U.S. by americans. They offer 4 different types of cores, I went with the high efficiency model, as it will cool my 216 as well as a small block if the 216 ever dies. Only down side is they build to order so I have to wait 2 weeks or so. Thanks for the feedback, I'll post some pictures when it arrives. | | |
