| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | i can buy some realy cheap priced tirers.225/75/16.will these fit in my wheel well properly are they to wide? on my 1948 1/2 ton.i was told 15 and 16 inch where standard.if they fit which 6 lug rim would work whith the tire i want to still use the original hubcaps.i would still have to buy the rims.thanks | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yes, they will fit and look good too. I have 7.5 x 15" wheels on the back of my 53' with2:85 tires. Tight but they fit.
I'd advise staying away from "really cheap tires" as your life and others depends on them. Buy the best you can afford. | | | | | Joined: May 2011 Posts: 10 New Guy | | New Guy Joined: May 2011 Posts: 10 | The bead area on those old original type rims may not be compatible with the modern radials Your size does not have an "R" in it, but you seldom see take off tires that are bias. Just a caution, they may mount on and hold air but may not fit properly to safely hit the highway. Also the old rims may be originally for tube type tires. Have a good tire shop look it over to be sure. | | |
