0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | I would like to change the color from black on my 53 chev bed. Rolled on Ureathane is on now. What prep, and what paint is best...much appreaciated Sepp 22
Plattelnjpichler
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | You need to either plane the boards to get the urethane off or sand the urethane off. The best solution is planing the wood. You could try some sanding to make the paint adhere better to the wood. Most paints don't go on very well over urethane. Sanding urethane is no easy task. Check out the local cabinet shops to see if they will plane the wood for you, many won't do it because the urethane is hard on their planer knives. | | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | Thanks for your reply shop shark...I thought I could re'coat with a color ureathane? Sepp22
Plattelnjpichler
