4 members (Shade Baby, Jon G, Gdads51, dt235sd), 93 guests, and 0 robots.
Topics128,118
Posts1,056,306
Members48,439
I would like to change the color from black on my 53 chev bed. Rolled on Ureathane is on now. What prep, and what paint is best...much appreaciated Sepp 22
Plattelnjpichler
You need to either plane the boards to get the urethane off or sand the urethane off. The best solution is planing the wood. You could try some sanding to make the paint adhere better to the wood. Most paints don't go on very well over urethane. Sanding urethane is no easy task. Check out the local cabinet shops to see if they will plane the wood for you, many won't do it because the urethane is hard on their planer knives.
Thanks for your reply shop shark...I thought I could re'coat with a color ureathane? Sepp22
Plattelnjpichler
