| | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | The place where the carb mounts has corroded and deteriorated. I am wondering if I need to remove the manifold and get this repaired or if it would be possible to get a new thick gasket and get it to seal with silicone or some other product. What d'yall think? My fear is that the deteriorated area is actually in one of the carburetor circuits. It has the Rochester G2. Also, there is a picture of the bottom of the carb. I do not want to swap the intake because this engine is all original and has been our family since new. see the intake and bottom of carb here. http://s1178.photobucket.com/albums/x376/remohbill/
| | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Can you file it down?... or fill it with JBWeld and then smooth it down?...then a new gasket. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Intake manifolds are pretty easy to find, why not just replace it?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Never, ever use a sealer where intake manifold vacuum is applied to the gasket. If you can remove the mounting studs and draw-file the mounting flange smooth, no problem. Stuff a rag down the manifold to keep filings out of the engine. It might be possible to use J-B weld or some similar type of filler to smooth the gasket surface, but I'd prefer a smooth file-finished surface, or a replacement manifold. A vacuum leak there can be terribly frustrating with its effect on performance. Jerry
| | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | You asked for pics now you got'em. See above in my original post. | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I would pull it and take it to a machine shop. I figure 10 bucks in gaskets, and 20 to the machine shop, and you have a restored surface | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A belt sander will do wonders for that thing. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | That was a chronic problem with those carburetors. The passageway in question carries exhaust gas- - - -it's part of the heat riser system. A leak there will put exhaust gas back into the intake, resulting in a condition like an EGR valve on a later-model engine stuck wide open- - - -lousy performance and an engine that won't idle. CAREFULLY drill and tap the rotted-away mounting studs, and draw-file or machine the gasket surface flat again. I'd suggest taking the manifold to a machine shop where it can be set up in a Bridgeport mill for both stud replacement and fly-cutting a new gasket surface. Draw-file the throttle base dead flat before reinstalling the carb, too. Jerry
| | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | hi, Jerry,
What is the problem with a sealer where intake vacuum is applied? I used permatex #2 on my Holley 1904 on my GMC 270 and have been having problems- likely vacuum leaks.
Dave
PS I found the answer from some other posts of Jerry's- the intake vacuum can draw the sealer into the engine, not a good thing.
