| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75310 03/24/2007 5:29 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | This is after removing paint with a dremel abrasive brush, rubbing it down with a scotchbrite pad, and rubbing it down again with a scotchbrite sanding sponge - 320 grit. I will be powdercoating these as is w/ high temp clear. http://rides.webshots.com/photo/2241425710071636143eVQveW They will sit on similar polished Rochesters on a polished aluminum Edelbrock and chromex ceramic coated headers or maybe a stock manifold that will be split(also ceramic coated). They will all be installed on the 261 I'm building. I will be using the same clear powder coated valve cover I have now on my 235 that can be seen in the bottom link. | | |
#75311 03/24/2007 11:52 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
#75312 03/25/2007 3:11 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Wow! Those look BETTER than new.  | | |
