Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (baldeagle), 118 guests, and 2 robots.
Topics128,274
Posts1,058,432
Members48,489
#75310 03/24/2007 5:29 AM
This is after removing paint with a dremel abrasive brush, rubbing it down with a scotchbrite pad, and rubbing it down again with a scotchbrite sanding sponge - 320 grit. I will be powdercoating these as is w/ high temp clear. http://rides.webshots.com/photo/2241425710071636143eVQveW
They will sit on similar polished Rochesters on a polished aluminum Edelbrock and chromex ceramic coated headers or maybe a stock manifold that will be split(also ceramic coated). They will all be installed on the 261 I'm building. I will be using the same clear powder coated valve cover I have now on my 235 that can be seen in the bottom link.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#75311 03/24/2007 11:52 PM
Hard work gone well!!!
~Jim
#75312 03/25/2007 3:11 AM
Wow! Those look BETTER than new. grin
