0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 35 | My 50 has the 4 on the floor. Its a torque tube driveline.
What is the fluid capacity of this trans (want to do a change) and what should I run? Does the rear end have its own reservour or are they linked through the torque tube?
Trans is very noisy in 1-3 then gets real quiet in 4th. Want to start with the fluid.
1950 3100 Project-just getting started
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I found that using 85W140 in my 4 speed helps the synchros work a little faster. My gears all are quite vocal with the "Chevy whine" until I get into forth. Forth gear of course is just a straight through connection. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | for filling a drained tranny i like to fight with removing the stick and pouring it down the hole rather than fight trying to get it in the fill hole one quart at a time and not all over me. i found over time im getting good at stick removal and installation. for just adding a little bit i use a little pump oil can to top it off. it takes a while but is not messy. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mike,
Be gentle with the stick/shifter retainer and it will oblige. It's all in the motion.
When I installed the SM420 in my Suburban last year (4 times, emptying it three times), I also figured out that filling through the stick/shifter hole was much easier, quicker, and cleaner.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Mike, Be gentle with the stick/shifter retainer and it will oblige. It's all in the motion. tim, the dump and the 40 are easy. it's the ashton that's hard. i think its the amount of spring it has compared to the other two. i also find that if you remove the vent on the rear and fill until it comes out the filler plug is simpler and also cleaner and in the mean time maintenance can be preformed on the vent. | | | | | Joined: Oct 2010 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 35 | Any else have recomendations on what weight to run in the trans and rear end? I'm seeing 90 weight and 80W140 listed so far.
Planning on buying some after work today.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | This topic has been kicked around a lot do a search to find some. There is a well-known rebuilder that has good info check out novak.com | | | | | Joined: Oct 2010 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 35 | I put 3 quarts of 80W90 (because that is what they had the store) and it has not overfilled out of the side fill hole. Is it supposed to spill out when full?
Also, the rear "u-joint housing" has a grease zerk on top of it, I assume I grease it not put oil in it?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | No, you do not put grease into the u-joint housing via the Zerk fitting. Transmission lubticant goes in there (and it eventually will be fed/filled from the transmission). Rumor has it that the Zerk fitting was used by the factory (and maybe dealers) to fill (or top up) the u-joint housing with transmission lubticant.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Rumor has it that the Zerk fitting was used by the factory (and maybe dealers) to fill (or top up) the u-joint housing with transmission lubticant. tim is right, no grease. my 40 has a 1/8th npt plug. either way its a real pain to add oil there. | | |
