2 members (78buckshot, NJC), 99 guests, and 3 robots.
Topics128,149
Posts1,056,819
Members48,456
#752779 06/07/2011 7:13 PM
I have a 74 Camaro clip on my 49 5 window. The rear end is from a 72 Coupe de Ville and has 5 on 4 3/4 bolt circle. Anyone know what hub (disc) will fit the Camaro spindles that has a 5 on 4 3/4 bolt circle?
The year of the clip, all Camero's from '67-'70 have 5 on 4 3/4" bolt patterns. You sure the Caddy didn't have a 5 on 5", most big cars did back then. If thats the case, you might find a big GM that will fit a Camero spindle, but it will take some digging.
Check out some of the brake venders web sites, they may be of some help.
Joe
I think a 5 on 5 GM hub will also have the big rotor, which won't fit to the smaller camaro caliper. My clip is from a mid 70's monte carlo, which also has a 5 on 4-3/4 pattern, and I found that a late 70's olds complete spindle and rotor assembly will bolt directly to the Monte ball joints. A simple swap. I got big brakes, and 5 on 5 bolt pattern. I don't know if it would fit to your Camaro suspension, but might be worth checking.
Thanks, I'll probably try to source some 5 on 5 hubs from a larger GM car if I don't use the Camaro rear end. Should have snagged the hubs from the de Ville when I had the chance! I'm leaning seriously toward keeping the Cad rear end because it has a very high gear ratio (about 3.09? IIRC) and this will be a cruiser, not a drag racer.
