0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | Thanks for looking, everyone. I am in the process of buying a 327, which is in a 1967 C50 Dump Truck. It's got a 2 barrel carburator on it now, and it's pretty safe to say that the motor is older than the truck. I'm curious though, because the ends of the heads have a strange double rectangle marking on the ends of the heads. I've looked for information and asked a few of those who know better than I, but they've not seen them before either. Does anyone know what this is, or means? Thanks.
1956 Chevrolet 3100 - "WonderTruck"
"I used to be 'With It.' Then they changed what 'It' was. Now what I'm 'With' isn't 'It,' and what is 'It,' seems wierd and scary to me."
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | High-performance 265's and some 283's from the middle to late 1950's used a head with a rectangular pad on both ends of the head, and two small rectangular projections on top. They were manily used on Corvettes. I believe they had slightly smaller combustion chambers than the standard V-8 heads. The "power pack" heads on the 4-barrel 283's had a rectangle on the end of the head, with a triangle centered on top of it. Those heads had 58CC combustion chambers. Try this link: http://www.fastnuf.com/Headguide.htmlJerry
| | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | THanks Jerry, I've looked at the very website you linked. But this is not on there. These are two large independent rectangles, standing up, lengthwise, and side by side. They are not on or near anything else, and do not have any projections on top.
The Dreamer in me hopes that they're some sort of rare, high performance head. The Realist in me says that they're probably a short run of the worst heads ever made, and somehow I wound up with them.
Would there maybe be a difference in 2 and 4 barrel heads? I have heard that there is, but I wouldn't know. I will try to get the casting numbers, and go about it that way. But I'd still love to be able to identify them.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It's possible you've got somebody's aftermarket heads like Dart, World Products, etc. How about posting a link to some pictures, or at least some casting numbers? Are they cast iron? The main difference in production heads was in the valve size and compression ratio, so the 4-barrel engines often got higher-performance heads than 2-barrel passenger car or truck engines. Jerry
| | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | Well I went and got the Casting Numbers off of the heads. 186, is the number. According to the link you posted, Jerry, the 186's were "Later hi-perf or “fuelie” heads," And something in me likes the sound of that. ha ha. But the markings are still strange. I tried to get the serial numbers, but it was getting dark and what with oils and dirt and whatnot on the motor I didn't bother too heavily with gettin 'em.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Why do you think the heads are older than the truck they're in? I think 327 was the V8 option in a 67' C50. | | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | Yeah, the truck's definitely older. It's a '56 3100 and I think the standard V8 in 56 was either a 265 or a 283. I bought this motor out of a 67 C50. I don't think it was the original for that one either.
