7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | working on a 52 that the cab has been jack around could someone tell me how wide the door opinings should be just below the door latch and how far apart the front pillars are from each other
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Very precise cab measurements are in the Factory Assembly Manual if you have access. I will look tonight and see what it shows. | | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | That would help a bunch ..........would there be one of those online ?? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I looked in the manuals project archive and did not see it there. Someone else may know or I may have missed it. There is a large portion of the manual focused on cab assembly/issues. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That would help a bunch ..........would there be one of those online ?? This might have the info you need. Oops, on second glance that's for cars. Sorry.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | From the 51 Salesman data book page 193.
Door opening at Beltline-31-1/2" at latch/handle area 35-1/4" at floor 32-5/8"
Could not find and exact for the pillars so I measured mine at the top of windshield to Centerline of pillar is 53" at the bottom it is 56" | | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | You'll be a lot safer if you fit the door opening to the door instead of some number. You don't have to off by much to make fitting your door a nightmare. | | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | You'll be a lot safer if you fit the door opening to the door instead of some number. You don't have to off by much to make fitting your door a nightmare. Thats what I'm doing dut would like a ref. point to go by Hey good job on all the pics of your truck been kinda using it to go by its helped alot !!!!! | | |
