2 members (papas52, carbking),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75221 03/21/2007 8:22 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I've tried looking through the 16 pages of oil filter threads in the "search" function for info on different shapes of accessory oil filter cannisters without much luck. Here's the question...I'm looking at an alleged 1953 GMC oil filter cannister..it is longer and narrower than the AD oil filters I've seen before. I did notice in one of my manuals that early 216's had (42-46) had what appeared to be long narrow cannisters. Were two shapes of cannister available from GM/Chevy ? | | |
#75222 03/21/2007 11:13 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steve,
In 1954, Chevrolet trucks had two GM (AC) accessory oil filters, 1 quart and 2 quart. In 1949/50 there was one oil filter available, 2.5 quart capacity.
Tim | | |
#75223 03/22/2007 12:31 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | GMC also had two oil filters, a "short" one on most trucks, and a "long" one for heavy duty trucks and busses.
#75224 03/22/2007 3:57 AM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Take a look at this ebay listing and tell me what you think.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=012&sspagename=STRK%3AMEBI%3AIT&viewitem=&item=220093565347&rd=1,1 | | |
#75225 03/22/2007 4:06 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1953 GMC (supposedly) oil filter canister - the eBay item posted above. 216 or 235 GMC? Maybe someone knows what the GMC canister looks like? | | |
#75226 03/22/2007 5:37 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Man, oh man, it looks like that thing came off the Titanic! | | |
#75227 03/22/2007 11:32 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | steveg found this 41-46 oil filter in a 41-46 [Chevrolet Truck] Accessory Pamphlet on Brad's \'41-\'46 website. | | |
#75228 03/23/2007 12:03 AM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Tim...Thanks for the assist. | | |
#75229 03/23/2007 12:52 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steve,
That filter style was a GM accessory (Chevrolet truck, at least) through 1954 (or 55-1st series. I would also like to find one. Am I correct in thinking that it had two flat straps around it?
Tim | | |
#75230 03/23/2007 10:00 AM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | This is my oil filter canister on my 1952 GMC 228 motor. It is approx 7 inches tall, 4 1/2 inches in diameter and about 14 inches in circumference. http://good-times.webshots.com/photo/2942034760090990065oZrriX I realize any motor could have been in the ebay GMC, but if it had its original motor it would be the 228. Check out the top of this page which shows what GMC engines were offered in what models in what years. The 1953 1/2 ton model would be the 101-22. http://www.oldgmctrucks.com/page0015.html I also looked at the right side of a 248 in my GMC maintenance manual and the 248 filter is shorter and mounted higher and more mid engine. Definitely looks different than a 228 filter. I think the ebay filter looks a lot like mine and probably came from a 228 GMC motor. Does it also fit other motors? Don't know. The ebay seller mentioning the 216 and the 235 could mean, as Tim alluded to, that he is one more person who doesn't know that GMC had their own line of engines during this period. Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#75231 03/25/2007 1:53 AM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Tim...It appears to have two straps and also it appears to be firewall mounted. I'm on the trail of two of them...I'll let you know. | | |
#75232 03/26/2007 12:04 AM | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I just obtained one of these filters that was attached to a 216 out of a 52 pickup. It has flanges on the back of the housing and uses 2 "U" type clamps which mount it to the intake manifold. I don't know how to post a picture here but can send you one if you wish. Fred
