4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#751857 06/03/2011 11:16 PM
replaced the 228 in my '53 gmc sub with a chevy 235 using the gmc bellhousing. a 216 starter and a 235 grind and will not engage the flywheel. telling me to put the 228 back in is not a help.any clues?
trhamilton #751860 06/03/2011 11:24 PM
Are you using a 6 volt starter on a 12 volt flywheel?
A 12 volt flywheel will have 168 teeth. A 6 volt flywheel will have 139 teeth.
It is possible to run a 6 volt starter on 12 volts, but it is not possible to run a 12 volt starter on 6.
I would never tell you to put the 228 back in... I would tell you to lose the 235 and put a gmc 270 or even better a gmc 302 in place of the 228!
