Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#751754 06/03/2011 2:45 PM
I painted the interior of my truck with PPG Omini base-coat and then clear-coat. Unfortunately I didn't take the doors off and now, as I'm ready to paint the exterior, I did remove the doors. I notice the pillars and door surfaces on the hinge side are not the best. I would like to re-do them. The question is, do I need to completely remove the clear-coat before touching up the base-coat, or can I scuff the clear-coat, and then base-coat and clear-coat on top of that? Thanks.
don
Donsz #751772 06/03/2011 4:26 PM
Ex Hall Monitor
Ex Hall Monitor
As a general rule paint is only a pigmented adhesive. It should make no difference where it's the colored base or the clear coat. Sanding with the correct grit paper should allow you to re-shoot your jams. Having said that, my experience with modern materials is limited so if I'm full of beans someone will point it out. grin
Donsz #751773 06/03/2011 4:29 PM
If you used the metallic color inside you may have to remove all the clear. If it is a solid color you can scuff the clear with as fine as 800-1000 grit and apply more base to that, then re-clear. That is what the pros told me and it seemed to work for me. Maybe you can get away with that technique with metallics too in the location you need to fix but someone more experienced will have to address that.
Chuck
Ex Hall Monitor
Ex Hall Monitor
I'd be really surprised if the presence of metallic in the paint underneath the clear would make any difference in adhesion of additional coats to the clear.
Tiny #751802 06/03/2011 6:54 PM
The paint is not metallic. Thanks for for the responses, much appreciated. Along the way, we determined Tiny is not full of beans.
don
Donsz #751812 06/03/2011 7:34 PM
Tiny- the explanation I got regarding metallic paint had nothing to do with adherence. It has to do with the light refracting thru multiple layers. I was told it might work but chances are you would see a difference with metallic paint. The solid colors do not share this problem. I have unfortunately had to fix this type of problem (not enough basecoat) a few times. I don't know how I miss some areas but I do.
Chuck
Ex Hall Monitor
Ex Hall Monitor
That might be Chuck if it's one of the translucent base colors in vogue these days. Good tip. Don, it's good to see I won't be stinking the place up today. grin
