8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 13 New Guy | | New Guy Joined: Jun 2011 Posts: 13 | Hi again, 1 problem out of the way, now onto the next. My gauges are new SW original style. The fuel gauge is not working, looks like the wires are connected. I have to take the seat out to get at the tank. Are the bolts coming through the floor to remove? also there is a lever on the driver side seems like it should slide, is that what its for? thanks
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Go to the section of the forum called Electrical Bay and look down about 15 posts. There are two threads that should give you all the info you need regarding the gauge.
Chuck | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The seat doesn't need to come out. The back cushion will pop out. There may be (3?) screws in the top rail but most of them have been removed.
The lever is to adjust the seat forward and aft. | | |
