7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#751307 06/01/2011 10:44 PM
i can buy some realy cheap priced tirers.225/75/16.will these fit in my wheel well properly are they to wide? on my 1948 1/2 ton.i was told 15 and 16 inch where standard.if they fit which 6 lug rim would work whith the tire i want to still use the original hubcaps.i would still have to buy the rims.thanks
oldchevyguy #751321 06/01/2011 11:49 PM
Yes, they will fit and look good too. I have 7.5 x 15" wheels on the back of my 53' with2:85 tires. Tight but they fit.
I'd advise staying away from "really cheap tires" as your life and others depends on them. Buy the best you can afford.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #753844 06/11/2011 6:57 PM
The bead area on those old original type rims may not be compatible with the modern radials Your size does not have an "R" in it, but you seldom see take off tires that are bias. Just a caution, they may mount on and hold air but may not fit properly to safely hit the highway. Also the old rims may be originally for tube type tires. Have a good tire shop look it over to be sure.
