Brrrr
place holder
5 members (52Carl, 2-Ton, Jims46, TUTS 59, 1 invisible), 96 guests, and 4 robots.
Topics128,271
Posts1,058,417
Members48,485
#750710 05/30/2011 8:37 PM
I'm installing a dual master cylinder to replace the original single on my '56 GMC 3/4 ton. I remember seeing a post on this years ago, and can't find it. The question is do I put the front wheels on the front reservoir and the rears on the rear? That makes sense to me. Still drums all around.
Well, my time went so quickly,
I went lickety-splitly
Out to my ol' 55.
As I pulled away slowly,
Feelin' so holy,
God knows, I was feelin' alive..... Tom Waits, Ol' 55
Yes keep the front of the master to the front brakes ,on my 52-3100 the master installed with the front of the master facing to the rear of the truck , I don't know how the master is mounted on a 56 GMC ,I used a 67 C10 master because the 67 had drum drum brakes. You could use a 67 C20 master just check and see if it's drum drum.
Pete
Actually, the rear port (pedal end) goes to the front brakes, the front port goes to the rear. Granted, with a 4 wheel drum system, it may not make a difference, but on a disk/drum system it does.
Bill Burmeister
Dave, i'm not sure if your M/C is here but this might help.
M/C plumbing guide.
More pix on Flickr.
Thanks for the tips- it is great to be going out to do a little truck work and have answers appear! The larger reservoir to the front makes sense, esp with discs. These are drums-however I will follow those recs in the off chance I find a way to go to front discs on this old eight lug... This MC is mounted in place of the orig under the floor, so the front is facing to the rear. And of course the speedo cable goes right over the top it because it is longer than stock.
Out to my ol' 55.
Feelin' so holy,
