| | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75101 03/20/2007 1:59 AM | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | I'm working on a '49 3100 and the tranny mount is missing the rubber pads.I ordered the repair pads from Classic parts.They sent a pair of the replacement rubbers and I would like to know how the original was.Shoud it have one on the top and one on the bottom?Hopfully someone has done this repair.Thanks,Chip | | |
#75102 03/20/2007 2:27 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Are you talking about the mounts on the bellhousing? I bought new ones and I believe that the metal and rubber were fused together. | | |
#75103 03/20/2007 3:29 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chip, I think this is the transmission rear mount that you are referring to. I do not know if a rubber pad goes on the underside (this mount was not used on '54 1/2 ton, even though the catalog says it was). Maybe someone who knows will post an answer. Tim | | |
#75104 03/20/2007 11:07 AM | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | Thanks Tim,That is the mount I'm referring to.Since I recieved 2 pads,did they intend for one to go on the underside as well?At $60.00 for the mount,I will fix mine.Just want to do it right.Thanks for the replys,Chip | | |
#75105 03/21/2007 4:35 AM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | FYI, The mount in question is very similar to the one used on a 54 hydramatic. I just went through my assembly manual and could not find a picture of the mount. I did dig mine out of the pile of parts and look at it. Mine is also missing the rubber parts, but I think the rubber parts go on each side of the large flat plate. This would mean the rubber parts would have to be cut to go on the two studs or the studs would have to be replaced with bolts. I think when I put mine back together I will replace the stud with bolts. Here is a picture of my rear trans mount. http://s101.photobucket.com/albums/...ion=view¤t=P9160009_edited.jpg | | |
#75106 03/21/2007 5:26 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The original unit was vulcanized rubber held with a couple of floating rivets. Some companies will re-vulcanize the assembly if you send off your pieces. I found an old piece of thick conveyor belting and made my own. As it is in layers I could strip off the areas I wanted to set the bolts and such in. Frankly its not rocket science and you should be able to figure it out. As a matter of interest I had a 53 on which the pad was never installed. There was no connection between the trans and the crossmember. It worked fine but I did fix it properly when I pulled the engine and trans for a rebuild. | | |
