4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#75101 03/20/2007 1:59 AM
Apprentice
Apprentice
I'm working on a '49 3100 and the tranny mount is missing the rubber pads.I ordered the repair pads from Classic parts.They sent a pair of the replacement rubbers and I would like to know how the original was.Shoud it have one on the top and one on the bottom?Hopfully someone has done this repair.Thanks,Chip
Are you talking about the mounts on the bellhousing? I bought new ones and I believe that the metal and rubber were fused together.
1951 1 Ton Completed
Chip,
I think this is the transmission rear mount that you are referring to. I do not know if a rubber pad goes on the underside (this mount was not used on '54 1/2 ton, even though the catalog says it was).
Maybe someone who knows will post an answer.
Tim
Apprentice
Apprentice
Thanks Tim,That is the mount I'm referring to.Since I recieved 2 pads,did they intend for one to go on the underside as well?At $60.00 for the mount,I will fix mine.Just want to do it right.Thanks for the replys,Chip
FYI,
The mount in question is very similar to the one used on a 54 hydramatic. I just went through my assembly manual and could not find a picture of the mount. I did dig mine out of the pile of parts and look at it. Mine is also missing the rubber parts, but I think the rubber parts go on each side of the large flat plate. This would mean the rubber parts would have to be cut to go on the two studs or the studs would have to be replaced with bolts. I think when I put mine back together I will replace the stud with bolts.
Here is a picture of my rear trans mount.
http://s101.photobucket.com/albums/...ion=view&current=P9160009_edited.jpg
The original unit was vulcanized rubber held with a couple of floating rivets. Some companies will re-vulcanize the assembly if you send off your pieces. I found an old piece of thick conveyor belting and made my own. As it is in layers I could strip off the areas I wanted to set the bolts and such in. Frankly its not rocket science and you should be able to figure it out.
As a matter of interest I had a 53 on which the pad was never installed. There was no connection between the trans and the crossmember. It worked fine but I did fix it properly when I pulled the engine and trans for a rebuild.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
