| | | Forums66 Topics128,180 Posts1,057,148 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 59 | Hey guys, what's the best way to clean out what I believe to be a clogged vent on the axle housing of my truck? It is a "mushroom" style vent, I guess you'd call it with a short post and a round top that sits like an umbrella.
Any ideas would be helpful!
Brian | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | They screw in, Remove it, throw it into solvent and don't reinstall it until you can blow through it freely. | | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | How would one know when it's clogged and what are the consequences if it is? | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | take it off the axle and give it a shake. the top of it should be free to move ans so should the ball that's in it. the consequence is that the rear could start to build up heat which comes pressure and could lead to seal leakage. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | 51 Ashton has it exactly right. My 51 half ton started to have gear oil leak into one rear drum. It occured to me that since I was losing gear oil, I should check the level in the differential to be sure I had not lost a significant amount. I removed the fill plug, right after a drive, and heard air escape. That led me to the axle vent, which was compeletly plugged by corrosion and paint. I soaked it in gun solvent, replaced and never had a problem since. I cleaned up the drum but never replaced the seal and haven't had a leak and that was four or five years ago. | | |
