4 members (wilbur53, 2-Ton, 2 invisible),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I've found a good running 261 in a 58 2 ton that I'm going to put in my 31 pickup. Due to the limited space in the cab I'm going to lose the foot start and put an ignition swith on the dash. What 235 starter would be compatible with the flywheel on the 58 261 and also have an electrical solenoid? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year flywheel will you be using?
Do you have a 6v or 12v electrical system in your 31?
| | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I want to keep the the original flywheel on the 58 motor. The 31 is 12v. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Probably any 12v 55-63 starter with solenoid that was used on a 6-cylinder manual transmission truck. 60-63 solenoid starters for 235/261 truck engines with manual transmissions should work fine.
Wait to hear from someone who has first-hand knowledge of other 55-63 12v solenoid starters will work with the 12v manual transmission flywheel.
