Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#750378 05/29/2011 3:08 AM
Members:
It's the weekend and I can't call langdons....
The HEI instructions are greek to me...Has anyone put one of these things on?
Please help...
Example" Rotate dist.until 6 points on internal star wheel line up with 6 points on stationary pole piece. Assure that the internal star wheel is ear the top of the stationary pole piece not towards the bottom"
What.......I can't find this star wheel...to start with and it goes south from there.
Has anyone documented this in pictures?
You can call me if you have the knowhow...I NEED THE HELP.
(831) 234-4502
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Jimmi_V #750594 05/30/2011 3:35 AM
What kind of HEI have you purchased?
beltfed #750661 05/30/2011 4:32 PM
It was made up from langdons...for a 235 motor..thats all I know. I did figure some things out. I took off the rotor cap and saw the star wheel...so I put the dist. on the motor, put the brace on( loosely ). lined up the star points..then I get lost. So I will call Langdons...
Jimmi V.
Jimmi_V #750674 05/30/2011 5:41 PM
I think the bottom line is that the slotted part of the distributor shaft actuallt drives the oil pump. I really think that Tom Langdon's intent was to go to great detail to make sure that you had the distributor seated properly so that you would not run the engine without the oil pump being driven. Make the call but I am sure that is what he will tell you. I asked him the question of the 10 guage wiring. He said that was to prevent any false triggering and not an issue of current draw.
