3 members (Peggy M, RLB, TUTS 59), 105 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#750598 05/30/2011 3:55 AM
V
V Offline
I'm working on the ignition system trying to sort things out. While turning the ignition switch on and off checking voltages here and there I noticed smoke coming from the resistor on the fire wall. The key had only been on for a few seconds (less than 20) and I shut the key off. Could this be due to the fact there is debris inside (i.e. spider-webs and dirt) or is the resistor bad or do I have something hooked up wrong? I Have not tried to start the truck so I do not know if it will or will not at this time I am only trying to figure this wiring out. Your help is greatly appreciated.
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
the resistor normally does get really hot - yes it could be smoking the spiderwebs away, and if it's a new resistor it's the lettering paint getting "cured" - probably indicates the points are closed and the coil is drawing it's full shot - you could disconnect the wire from the coil to the dist and see if it stops the heating
I'm with Bill, if the points are closed when not running the resistor will smoke.
My Blog
V
V Offline
Thanks for the Info. I wasn't sure since I am hooking things up that were never in place when we got the truck. I was trying to figure out how to do the resistor by-pass circuit on a modern starter solenoid and a push button starter.So it was entirely possible that I got something screwed up.
Jessica's Truck
There are two small-diameter terminals on a Delco starter solenoid. The one marked "S" gets the voltage from the push button, and the "R" terminal goes to the downstream side of the resistor or the + terminal of the coil.(Different ends of the same wire) The only time the "S" terminal of the solenoid gets battery voltage is during cranking, when the solenoid is pulled in and supplying current to the starter motor.
V
V Offline
Jerry,
Thanks that is how I have it hooked Up, I guess my confusion is does the violet wire go on the s or r terminal? I'm guessing s since I do not believe there was an r terminal on the old stomp starter.
Jessica's Truck
