2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75042 03/19/2007 4:57 PM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I removed the intake/exhaust manifolds on my '51 Chevy 3604, original 216 engine last night. Boy was that fun breaking those nuts off, only took a couple of hours. The exhaust manifold has the usual carbon in it. I did a search and couldn't find any information on cleaning it. Should I even bother with it, it'll blackened right up again won't it? And is it safe to media blast(coal slag) the exterior of the manifolds, being sure to seal up the openings of course? Thanks in advance, Jeff. | | |
#75043 03/19/2007 6:20 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It's always fun tearing down a 50 year old engine that is stuck like glue, isn't it? I certainly would clean all the carbon out of it. That was deposited over a long time and probably because it was running pretty rich. A properly tuned engine should have a grey exhaust with little carbon deposit so yes, by all means clean it. As for the media blasting, well what can it hurt outside or even inside? It could only help smooth out the cast iron. Not sure about coal slag however as the proper media...sounds harder than the hinges on hells front door. | | |
#75044 03/19/2007 7:26 PM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Dave, I was thinking it might not hurt to blast the inside, but I was afraid of any pieces that might remain in the intake even after a good blowing with compressed air. I have been using coal slag on all of my parts. Have not tried it on panel pieces such as fenders or door, I don't know if it will warp the metal or not. Thanks for the input. What else could I use to remove the carbon build up deep inside the exhaust manifold? Jeff | | |
#75045 03/19/2007 9:34 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Steam cleaning or just hot water works great on carbon deposits. It dissolves in water. You can also mix up a big bucket of red devil lye and let the manifold soak in it for a few weeks. It won't hurt the metal but all the carbon and oil will come out. Wear gloves and don't get any in your eyes.
#75046 03/20/2007 4:36 AM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Thanks for the tip 4ontheFloor. I just media blasted it this afternoon. Now I can clean the inside, blow it out nice and dry and shoot it. Which is what I wanted to do to it when I was trying to get the mother off the exhaust/tail pipe. I hate rust! Thanks again, Jeff. | | |
#75047 03/20/2007 12:00 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Coal slag? That stuff is so nasty that I'm surprised anyone would use it. Try aluminum oxide. It cuts better and doesn't crack or pulverize as bad. You can paint the outside with an "Eastwood" hi-temp exhaust paint which comes in several different styles. It will look sharp.
#75048 03/20/2007 10:37 PM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I couldn't find any silica sand here in town at any of the box stores. They just had coal slag, I haven't checked the lumber yards though. Other than it being pretty dusty, it works great on everything I've used it on. When my supply runs out, I will try aluminum oxide or silica sand, if I can find it. | | |
#75049 03/21/2007 12:31 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | 53MONEYPIT.I haven't seen a gray exaust pipe in 30 years. And be4lieve me I look at a lot. | | |
#75050 03/21/2007 2:07 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | And you never will with unleaded gas. | | |
#75051 03/21/2007 2:40 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | The factory would have blasted it with steel shot in a tumbling basket, to remove any sand left over from the casting process. I dont think you can do anything close to this that would harm it or leave something behind that would either. | | |
