Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 129 guests, and 4 robots.
Topics128,275
Posts1,058,571
Members48,492
Hi Folks,
Just wanted to show my LCF I bought a little bit more than a week ago. It's now up at my friend Matt how will tinker and fix it so it becomes roadworthy and free of major rot.
Here are some pics:
Front
Rear
The frame / rear axle is a bit funny. They have basically put one extra frame rail on the truck above the original one. When doing that the put the main springs under the rear axle and the helper springs above. This truck has been a old Pepsi delivery truck, so maybe this is something common to drink delivery trucks.
Funny frame and rear axle
If anyone knows a bit about this it would be nice to know more. Anyways will be back soon when Matt gives me an in depth report.
Burbly Dyna
PS: My Burb is on it's way back, with new suspension and all smile.
To my eyes it looks as if the lower frame rails (including the kickup over the rear axle) are the original rails for the Pepsi delivery truck and the uppper rails were added some time later to let a later owner more easily install a more "normal" body. Th low rails let them put on a low body floor for the storage and delivery of the Pepsi product. This let them have a lower lift height, a serious benefit if you had to hand bomb all the product off the truck, even more so if you had to do it to load.
I don't know about that vintage, but some newer trucks of this type have a longer extension behind the axle to allow 2 (or more) bays ahead of the axle, one over it, and one behind. A quick google on "beverage body" came up with several sites with photos of completed trucks including http://www.beveragebody.com/ but I didn't find photos of a dropped chassis waiting for body installation.
I sure like those LCF's. I drove one as a kid, well sort of not on the road. It was a 59 also.
Hi Grant
Your probably right, I just looked at one of the other pics very carefully and I can see a similar kickup just front of the rear body mount. Question is if I should try to put the frame back as it was originally?
The extra frame rail should make it pretty rigid especially if we box it properly to the lower original frame rail. Matt got to check the front kickup better and possibly make it stronger if needed.
Found this pic on flicker, granted it's a Ford but my truck probably looked very similar.
1968 Ford N-Series Beverage Truck
Cheers Dyna
J M Offline
Dyna
Nice looking truck. What are your plans for it in the future?
Have fun
Jim
Hi Jim,
It will be a car hauler. Much in the same way as the lines as the Spartan car hauler currently for sale at Fast Lane.
Spartan 100 car hauler
I like the LCF better since it makes the truck shorter and easier to maneuver. Beside it's better looking too smile.
Cheers Dyna
For some reason someone wanted to raise the frame rails. I don't like it when people weld stuff to the frame. Can weaken the frame and allows cracks to start. There are no older factory frames that are welded, well for trucks anyway. I don't think you will see much welding on a new Kenworth frame either.
