0 members (),
119
Mod | | | Forums66 Topics128,088 Posts1,056,416 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: After fighting with putting on headers and the orignal intake manifold...man you need 3 hands and the washers/holddowns needed to be modified,ground down to sit properly, plus fighting with the 3 piece gasket...I was fit to be tied. Then I go and try to torque the bolts down...There isn't any room for the socket ...only the outside bolts ( I changed out the guide pin with a bolt).....So I snugged it up real good. What else can I do..? And I find out I cant run my external oil filter on the manifold because it hits the headers...AGHHHHH. Bad night. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You need a set of crowsfoot adapters. If you find them, there is a box end style crowsfoot that works very well, and will not round off the bolts like a regular crowsfoot can.
Bill Burmeister | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "Members: After fighting with putting on headers and the orignal intake manifold...man you need 3 hands and the washers/holddowns needed to be modified,ground down to sit properly,"
Jimmi, I saw that topic on this or another forum. As I recall stepped holddowns got the job done simply and easily. Those are easily fabricated from flat bar stock and a milling machine or even a hacksaw, grinder and/or file.
"plus fighting with the 3 piece gasket...I was fit to be tied".
Scotch tape or masking tape will hold the gaskets in place temporarily.
"Then I go and try to torque the bolts down...There isn't any room for the socket ...only the outside bolts ( I changed out the guide pin with a bolt).....So I snugged it up real good. What else can I do..?"
Reach in from above or below with a wrench. You know what the correct torque for a bolt of that size feels like. If you don't, put a bolt in your vise and twist it until it breaks. You'll never overtorque a bolt after doing that experiment.
"And I find out I cant run my external oil filter on the manifold because it hits the headers...AGHHHHH. Bad night."
A home made bracket will position it correctly.
Now we're having fun, right?
Ray
