7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51), 130 guests, and 2 robots.
Topics128,109
Posts1,056,267
Members48,439
#749758 05/25/2011 10:09 PM
I'm replacing the 216 in my 1950 3600 with a 261.
I just received the "new" engine and started looking over it and thinking about what issues may pop up in the swap.
The main thing I see is that the oil filter and lines will need to move to allow room for steering column. Any ideas where to get replacement lines or other options for moving the oil filter?
1950 Chevy 3600 3/4 Ton
[image]http://gallery.me.com/russeverett/100027[\image]
I'm using a remote filter set up I purchased from Summit. I'm just not sure where I'm mounting it yet. I've seen them on the high side firewall, inner fender shell, and low on the block using a homemade bracket. It might be one of the last things I mount after sorting out of other attachments such as the intake ,exhaust, generator,etc.
Drew
I'm not familiar with Summit. Can you give me some more info- website or part #?
thanks!
thanks!
www.summitracing.com
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
ElCid93
There are two different types of oil filters used on USA 261s: a by-pass filtration canister, used from 1954-1957; and, a full-flow canister, used from 1958-1963.
Both systems can be easily mounted on the intake manifold (as original), or mounted low on the block, or mounted in a remote location (off the engine assembly). The original location is forward of the carb for the by-pass canister and rearward of the carb for the full-flow canister.
Hoses for the by-pass system are readily available (from most reproduction parts vendors) and full-flow system hoses can be easily made (with parts from Jeg's Summit Racing, etc).
What year 261 do you have?
You local flaps can supply you with a remote filter mount as well as custom build the hoses for you once it's mounted.
Wix filters offers a couple of different remote filter set ups that are easy to get, easy to work with. And any good hydraulic hose shop can build your hoses.
Drew
WIX # 24764 is the remote fitler mount and Wix Filter 51515 is one of the full flow filters that will fit this base. Mount it where you want it, have hoses built locally. Your local auto parts store should stock this and be able to build hoses.
ODSS Lawman
ODSS Lawman
Here is a photo of the oil system on my 261.
Oiling system
I could not run the stock setup since it would not bolt onto my Offy intake. To dress it up, I painted the spin-on fitting you can buy at most FLAPS black, and I use a NAPA gold 1515 oil filter and spray paint it yellow. Looks like a modernized AC Delco setup.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Hello, Chris,
I forget what year your engine is, but it looks like a 58-63 full-flow oil system (the hose ports look to be 1/2" NPT).
We have not heard from ElCid93 regarding what year 261 he has. If it is a 54-57, he'll have to either use an original by-pass system (mounted on the intake manifold or elsewhere), or he could use a more modern remote set-up (with a filter head like yours and mine) but he would have to put a flow-restrictor in the input line, even if he uses a narrower diameter hose.
Here is another photo of full-flow filter mounted on the firewall.
Here is the original manifold-mounted full-flow canister on a 1958 engine.
Here is a remote filter head mounted low on the rear of the block (same full-flow 1960 engine as shown above).
Thanks for the input. I've been sidetracked with other projects (happy wife and all that), now I'm back to the truck.
I've got a 1961 engine with the oil setup behind the carb.
I'd like to keep it on the block and just move it in front of the carb. The kits on the Summit site look like what I need. I was under the impression I'd have to use stainless formed lines instead of the flexible lines.
