| | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 20 New Guy | | New Guy Joined: Jul 2009 Posts: 20 | I'm replacing the 216 in my 1950 3600 with a 261.
I just received the "new" engine and started looking over it and thinking about what issues may pop up in the swap.
The main thing I see is that the oil filter and lines will need to move to allow room for steering column. Any ideas where to get replacement lines or other options for moving the oil filter? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I'm using a remote filter set up I purchased from Summit. I'm just not sure where I'm mounting it yet. I've seen them on the high side firewall, inner fender shell, and low on the block using a homemade bracket. It might be one of the last things I mount after sorting out of other attachments such as the intake ,exhaust, generator,etc.
Drew
| | | | | Joined: Jul 2009 Posts: 20 New Guy | | New Guy Joined: Jul 2009 Posts: 20 | I'm not familiar with Summit. Can you give me some more info- website or part #? thanks! | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I'm not familiar with Summit. Can you give me some more info- website or part #? thanks! www.summitracing.com | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ElCid93
There are two different types of oil filters used on USA 261s: a by-pass filtration canister, used from 1954-1957; and, a full-flow canister, used from 1958-1963.
Both systems can be easily mounted on the intake manifold (as original), or mounted low on the block, or mounted in a remote location (off the engine assembly). The original location is forward of the carb for the by-pass canister and rearward of the carb for the full-flow canister.
Hoses for the by-pass system are readily available (from most reproduction parts vendors) and full-flow system hoses can be easily made (with parts from Jeg's Summit Racing, etc).
What year 261 do you have?
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You local flaps can supply you with a remote filter mount as well as custom build the hoses for you once it's mounted.
Wix filters offers a couple of different remote filter set ups that are easy to get, easy to work with. And any good hydraulic hose shop can build your hoses.
Drew
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | WIX # 24764 is the remote fitler mount and Wix Filter 51515 is one of the full flow filters that will fit this base. Mount it where you want it, have hoses built locally. Your local auto parts store should stock this and be able to build hoses.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Here is a photo of the oil system on my 261. Oiling system I could not run the stock setup since it would not bolt onto my Offy intake. To dress it up, I painted the spin-on fitting you can buy at most FLAPS black, and I use a NAPA gold 1515 oil filter and spray paint it yellow. Looks like a modernized AC Delco setup.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2009 Posts: 20 New Guy | | New Guy Joined: Jul 2009 Posts: 20 | Thanks for the input. I've been sidetracked with other projects (happy wife and all that), now I'm back to the truck.
I've got a 1961 engine with the oil setup behind the carb.
I'd like to keep it on the block and just move it in front of the carb. The kits on the Summit site look like what I need. I was under the impression I'd have to use stainless formed lines instead of the flexible lines. | | |
