| | | Forums66 Topics128,084 Posts1,056,087 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | I'd like to shut off the water to the heater in the summer. The heater hoses are going in to the original heater on my '54 Chevy 3100. I know it's not hard, but, knowing just what to buy will make it that much easier. Thanks for your help. Dennis | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | auto parts has shut off valve for your heater.
dan-pa
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | ^^what he said.A valve is installed in one of the hoses | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Your local hardware might have what you need, too. Mine did. There is a photo showing valve I used on my photobucket link. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You need one of these. Mount it up by the thermostat housing.
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | If you are not that concerned about originality, a 3/8 inch ball valve from hardware store, Home Depot, etc, works great. It is similar to what 40casey used. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Or take off the lines from the water pump , replace the hose connectors on the water pump with pipe plugs (3/8), and slip the hoses back over the pipe plugs. You can even put the hose clamps on if you want to.
This gives the originality "looks" and cuts off the hot water to the heater.
Put your hose connectors back on next fall for heat
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Google Cooling Depot. I used their valve # 111 746 28V that is cable controlled. You can manually control it under the hood or do what I did was to hook up a cable and control it from inside the cab.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | hippy,
Are you referring to: B & B Dixon Automotive Inc/Cooling Depot Inc?
Do you have a website address?
| | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Tim , I can't find the box that the valve came in but try your locale flaps store and look for a 5/8in. in and out valve for a Chrysler, also google heater valve auto.
| | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | Thanks guys. I'm going with 40Casey's fix on his truck. His truck, by the way, is awesume! | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | On my 56 3200 235, I took an idea from the forum and installed an in line valve that I got at Advanved Auto. They had a black plastic unit that had a control mounted on the one side. If you wanted to reverse the valve for the flow it was possible to relocated the cable mount unit on the other side of the valve. I mouned it under the battery box and attached it to the temp arm on the deluxe heater control in my truck. I have a standard heater. I also connected the heat/defrost arm to the flip arm on the front of the heater box. Not enough throw but set for full defrost at defrost setting on control and mix of heat and defrost on full heat. Local TV tech rebuilt the fan switch and I use it to control the blower. Almost like real! The guys here think its factory. Just using here in the summer and the defrost for early morings or evening is most important. | | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | I still haven't gotten the part to shut off the heat, but I did take my first First Place this weekend. It was the 1950-54 division (all makes and models) and I just added a Photobucket link to my profile. I'm a happy man. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Hey Willy, great lookin' truck!! Was wondering what size and brand of tires you put on it?
BTW, If you have a Tractor Supply store nearby they have exactly the valve you're looking for. All brass.
Spot
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | sweet_willy , that's one great looking truck ! Congrats on the win !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Old air sells two cutoffs I would suggest you use. One is a manual cutoff to go on one of your hoses, the other is a cable operated valve that will adjust the hot water flow to your heater. That way you can adjust the heat in the cab on a not-so-cold day. http://www.oldairproducts.com/catal...s/accessories-c-1_50000000_33000000.html
~Jim
| | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | I'm going to have to check that out for you in the morning. I honestly don't remember. I did get them at Coker Tire in Chattanooga which isn't that far from me. I also got the rims there. I'll let you know what size they are. | | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | Spot, the tires are P215/75R15 Coker 2 1/2" WW, the rims are 15X7 Smoothies both are from Coker Tire in Chattanooga, TN (423) 265-6368.
By the way, as you suggested I stopped by Tractor Supply today and found the brass ball valve. Thanks! | | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | I installed the ball valve today. Let her run about 20 minutes or so and no leaks. Life is good and much cooler. Thanks to all who offered suggestions. Learned a lot as usual. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Pics! Where are the pics?
~Jim
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Willy,
Thanks for the specs on your tires. I'll contact Coker or go online and look around.
Also, glad you were able to find the brass ball valve I told you about. I've learned that Tractor Supply is a good source for odd pieces we need for our old trucks.
Spot
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Willy,
I understand the principle of the hot water circulating through our heaters, but without the fan blowing accross it was the heater putting out that much noticable heat? And did the newly installed shut off valve make that much difference?
I'm only curious because, if it did, I want to install one this weekend.
Spot
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Willy,
Spot No fan, no heat, at least not much. However you being in SA you won't need it much.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No fan, no heat, at least not much. A box in your cab with 180° water circulating through it on a 100° day is certainly noticeable. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If sweet_willy has a 1954 Chevrolet truck (as indicated in his profile) and he has a GM heater, it is either a recirculating heater or an Air Flow (or Fresh Air) heater. The hot water will not flow through the Fresh Air heater unless the valve is open; however, the heated water will continuously circulate through the Recirculating Heater, heating the cab. http://1954advance-design.com/Documents/Accessories/Booklet/Page1.jpg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The way I read it he had no valve at all to begin with. With no valve water will flow no matter what heater it is. | | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | Spot, shutting off the water to the heater made a significant difference. I went to the Cavalcade of Antique Cars on Saturday. It's a thirty mile cruise to a cruise-in in St. Joe's Park, TN. It was in the mid-nineties and I was soooo glad I had put that shutoff in. My wife didn't ride with me that day, but she would have been even more grateful than I was since the heat comes out right at her feet. I highly reccommend putting the valve in. It's cheap, it's easy and it works. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | This is an unrelated question for sweet_willy. I tried to send you a PM but, you are not accepting any. I am about to send my '51 3100 out for paint and after seeing the pictures of your truck I am rethinking the black and green I have now. Can you tell me what colour your green is? It looks absolutely great. Thanks. | | | | | Joined: May 2011 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 49 | Peter,actually my wife picked out the color. I told her I wanted a dark green but not too dark. I have some paint left over, it's in the shop. I'll check the color for you tomorrow. | | |
