1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 11 New Guy | | New Guy Joined: Dec 2006 Posts: 11 | Is the cab portion the same (over the drivers head) as a pickup...will a pickup headliner fit? Any great ideas to finish the roof cargo area without going show quality expensive?
Lead, follow, or get outa the way. 50 Chevy 5 window, 65 chevy panel
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | No headliner in the pickup, all steel. I'm thinking of a 73-91 Suburban headliner for my burb. | | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Might be a bit expensive but I was thinking of finishing mine off with some kind of light panels. Like the ones that flash on Cash Cab.  | | | | | Joined: Dec 2006 Posts: 11 New Guy | | New Guy Joined: Dec 2006 Posts: 11 | Will the carpet from a pickup fit the panel?
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | 1/8" Tempered hardboard, aka Masonite, is found in the Panels & Suburban Carryalls. | | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | Someone posted a suggestion to use magnetic vinyl sign material. I thought was fairly slick. It can be cut to fit between the the cross pieces and stays put without glue. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Are you looking for acoustics, aesthetics, originality or functionality...virtually any material, that lays flat and can be attached will work, but form & function, will determine your choice of materials. Tempered hardboard is the factory application. | | | | | Joined: Sep 2009 Posts: 5 New Guy | | New Guy Joined: Sep 2009 Posts: 5 | Did they use the same material all through out the headliner? Does anyone have pics of it installed?
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | headliners originally were pieces in between the bows, unfortunately you need a piece about 54" wide to reach the sides. I am waiting on a sample of plastic that is wide enough, The company uses it to line barn walls. the carpets are the same, but may come up short at the burb "step" behind the front seats. Check out Stockinteriors.com for carpet, they will sell additional pieces to match for the rear. | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | plastic looks good! i'm getting the 1/16 thick one long enough to reach the front doors, then do cab in a separate piece. | | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | I don't know if you'd be interested in doing it this way, but here's mine- http://s660.photobucket.com/albums/uu326/Old64Suburban/ I insulated n soundproofed between the ribs, screwed 1X3s to the ribs longwise(5), and after spray gluing the ceiling material to some 1/4 Masonite I'd cut to fit, I then contact cemented the panels to the 1X3s. It took 3 pieces, leaving 2 seams across. For these, I wrapped screen molding with the material, and used a brad nailer to attach these over the seams. You have to look for the nail marks to find them. I believe a pin nailer would be even less conspicuous, but you'd want to nail at a little bit of an angle, since they have no heads. | | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | Forgot to mention that someone had recently asked about headroom loss. After replying that I thought there'd be some loss of headroom, I doublechecked and realized I still had plenty. I'm 5' 10". | | | | | Joined: Dec 2006 Posts: 11 New Guy | | New Guy Joined: Dec 2006 Posts: 11 | Nicely done! Thanks for sharing
