| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 9 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 9 | Hello, Does anybody know the exact measurement of the height of the grille on the 1953 Chevrolet 3800 series one ton pick-up, I understand they are slightly taller than the 3/4 or 1/2 ton models, Thanks | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | 3800 is same as 3/4 & 1/2. 1 1/2 & 2 ton are taller.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Mar 2009 Posts: 93 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 93 | Not sure about the 1 ton, but the 1.5 and 2 tons are about 3-4inches taller than the 1/2 and 3/4 tons. Grill widths are the same. The actual horizontal bars in each truck are close to the same size though only about .125 to .25 inches difference in height. The main difference is the vertical supports. However if your supports are good they can be switched. I bot a .5 ton chrome grill and put it in my 2-ton truck, by using the .5 ton horizontal bars and the 2-ton supports. | | |
