8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#749096 05/23/2011 5:27 AM
Hi everyone.
My name's Toby and I just pickup up a 55 gmc 100. it has a 248 and a four speed on the floor. it's an early second series that uses the smaller 1st series rear window. It had been sitting for only about 10 years according to the license plate.
I poured 2 gallons of gas into the tank. a little into the carb, and it fired right up. it has a one barrel holley. seems to run perfectly. I drove it around the yard and other than no brakes, it drove really well. This was all yesterday. last night I flat-bedded it home and this morning I started to take apart the brakes. I've rebuilt the original two front wheel cylinders, and I've removed the master cylinder.
I need to know how to remove the rear drums. anyone out there know?
Thanks in advance and what a kool website!
Toby
Joy Offline
Welcome to Stovebolt! Go on over to General Truck Forum and ask you questions there. There is a lot more guys over there. Good luck and glad you joined, your in the right place. thumbs_up
Joy #749124 05/23/2011 12:28 PM
Hi Toby,
Welcome to the bolt. Like Joy said you are in the right place.
Good luck with your truck.
Welcome
Chris
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
Leo Offline
Moderator
Moderator
Hi Toby, welcome! If the drums aren't coming off easily, they must be seized. Mine just pulled straight off.
Leo
I'll head over to that forum. 53panel. will I hurt the axle shafts by heating them up and beating on them with a sledge?
Leo Offline
Moderator
Moderator
Probably, they can shatter, although I have pounded on them at times.
Welcome to the bolt tob4000. We're here to help.
Hi Toby,welcome from a wet'n'windy Scotland.
More pix on Flickr.
